Can a GTX 750Ti edit 1080p videos easily with Premier Pro?
I have an old i3-2100 CPU so I thought to put it to use a GTX 750Ti, 8GB DDR3 RAM and a 120GB SSD storage.
Can these specs handle 1080p video editing on Adobe Premiere Pro 64 bit? :innocent:
Yes u can.I’m using the same gpu.Make sure u have installed cuda toolkit to get the best performance of the GPU
Extract and copy this file to c:/windows/syswow64/ to enable cuda
cuda_enc_windows7_8_64bit.zip (1.68 MB)
Hi, not sure about Adobe as the 750TI is already very old. Maybe you could use some MOV converter or something like that.
Either way you should experiment with it.
