There are so many GPUs. I am trying to put together my first computer how should I go about pick a GPU.
id start with price point
look at compatibility and what your looking to run. do you want ray tracing 4k stuff like that.
you should say a budget and from there I would tell you, and the resolution you play and what games
Definitely need a budget, but my rule of thumb is around 50% of the overall computer should be GPU.
That being said I picked up a 1070ti on sale 2 years ago for around 250 dollars I believe? I have felt absolutely no pressure to replace it yet.
