Best GPU for the money.
Hey guys, I was wondering what the best GPU is if you’re looking for a good price/performance ratio.
For me I always thought it was the 1060 but I just got one and it’s actually not powerful enough to play modern games like warzone.
In your opinion what GPU gives you the most bang for your buck?
I would get an rtx 2060 super
depends what you want really are you trying to get 4k stuff like that
Go to the website gpubenchmark the keep a list of benchmarks and shows the best gpu’s of the moment
2060 super is good in 2k and the in 1080p is one monster
RTX2060 is a good option.
Nvidia GeForce RTX 3070
I would like to refer, the RTX 3070 is also superb for its capacity to pair the top-string Turing graphics label, the RTX 2080 Ti, for less than half of its value tag.
RTX 3060 is best for the money in current market. but still graphic cards are too high TMP.
but what’s your budget?
using 1660s :wink:
I guess 3060 is the best option. My laptop has this GPU. Tbh, I chose this laptop unexpectedly. I was reading this article Best Credit Cards in Canada for 2022 | GreedyRates.ca , and the Lenovo Laptops ad popped up on my screen, so I clicked it accidentally. Then I was redirected to the page with the Lenovo 2.8k 100% sRGB laptop. I’m a designer, so this machine is literally perfect. It’s a so-called MacBook pro killer, you know. So, depending on your budget, I highly recommend you buy a 3060 or 3070.
