I think I have some issues with my 450 power supply of my PC. My Hard disks will frequently turn off and on and I can hear the read/write header scratching the disks at that time. So how can I find if my SMPS is failing?
When my power supply was about to fail i used to hear some click sounds and flashes.Sometimes my PC won’t power up at first try.
When you feel that some hardware isn’t being powered well! cool:
Usually, it doesn’t turn on!
If your computer turns off when you try to do a more power hungry task.
