Hello guys my laptop fell, it only shows grey screen when powered up, I tried connecting it to a monitor with the hdmi port, no signal. The light indicates that it’s accessing the hdd though
Does screen appear to be cracked? If not, there could a lose contact in board.
And it’s good to take it to the service center.
Or if the warranty period is over and you can take risks then try remove the RAM and insert it again.
Thanks I’ll try that ![]()
Good luck and let us know what you did to fix it after it’s fixed.
