[MT6582][Unofficial] [Stable]MiUi 8.7.15 for lenovo A5000[UPDATED 2020]
[CENTER][ATTACH type=“full” alt=“rsz_miui-8-xiaomi.jpg”]59[/ATTACH]
Phone Posted:
• Videoconferencing for VoLTE Contacts Improved
• The history of contact search
• Weather Improved
• Ability to select the units of wind speed measurement
• Security Added
• A new installer application with built-in Antivirus Corrected
• Sometimes, the game hung when using Game Booster traffic Improved
• Improved traffic monitoring Calculator Improved
• Updated data provider rates OTG Corrected
• Returned performance OTG cord AutonomyImproved
• Improved autonomy
[ATTACH type=“full” alt=“screens.png”]61[/ATTACH]
[/CENTER]
ROM features
1.SIM 2 3G WORKING. NOW ITS DUAL 3G - FIRST FOR MT6582
2. Beautiful MIUI 7 - Chinese beta[Credits to MIUI Team & Team Mix for porting]
3. Online t-hemes,wallpapers,ringtones,etc..
4. More Battery Efficient
5. Smooth
6. Modded dialer , settings , In Call UI and new File manager
7. Good Camera Quality
8. All Unwanted/chinese MIUI apps Removed
9. Play Store working
10. Super Compressed to 550 MB
11. Modded launcher - No more icon overlapping
12. Based on 6.12.5 Beta
13. Dirac HD working
14.New Power-saving Mode.
Bugs
-----No bugs----if u found anything then reply here
[this ROM can be ported to all MT6582 devices running Android 4.4]
Thanks to:
MIX TEAM FOR PORTING
Lenovoa5k blogger
INSTALLATION:
If you are using the stock lollipop or any custom lollipop based ROM then first flash your stock ROM then install TWRP. Backup your NVRAM and wipe everything excluding Internal Storage and MicroSD then restore your NVRAM then install this rom.
If you are having any issue with volume rocker then flash the fix file over this ROM.
UPDATE 2020 March 29
All the custom ROM links for A5000 are broken however I had DEO ROM available on my Mega Drive so here is it:
A5000_S029_DEOROM.zip786.9 MB
https://mega.nz/file/s0MySKYS
Im not sure if it works or not so don’t blame me
This ROM is 100% working and i have tried it on my lenovo a5000.
Screenshots:
:slight_smile: Thanks a lot this is the only stable ROM for a5000 i have seen so far. The adaptive light is not working but the volume rocker worked without having to flash the fix.
Tried it, awesome ROM.
Boss cant install the zip
What error do you get?
Couldn’t downloaded
Stable - MiUi 8 For Lenovo A5000
Sir do you know how to fix the camera
Check on updates tab.
This 8.15 sir ?
The latest version available here is 8.7.3.9
How can i fix the camera the video of facebook and youtune isn’t working how to fix it ?
Download the camera fix here. Video playback issues maybe fixed by the developer. If it’s done ill update it here. Please rate the ROM here.
YouTube and Facebook is working fine, I just checked.
what if i flash the kitkat rom then flash the custom kernel for touch issue. cdoes this rom will not adopt the touch issue for downgraded a5000?
There is no touch issue!
Can you add delicious Vietnamese language package to this rom?
I’m not the actual developer of this ROM i shared it here to make it easily available. This ROM has been developed by LA5K Blogger and he is not a registered community member. But you can request other developers in this community.
