[ATTACH type=“full” alt=“photo_2020-07-28_19-40-00.jpg”]270[/ATTACH]
Download MIUI 12 Stable 12.0.0.2 for Redmi Note 7 Pro based on Android Q
[COLOR=rgb(44, 130, 201)]MIUI 12 Full changelog
[li]Highlights[/li][LIST]
[li]MIUI 12. Yours alone.[/li][/ul]
[li]System animations[/li][ul]
[li] New: All-new physically-based animation engine with advanced architecture will refresh your device’s look.[/li][li] New: Dynamic window technology takes switching screen orientation to a new level.[/li][/ul]
[li]System visuals[/li][ul]
[li] Brand new visual design works for all types of content and languages.[/li][li] Magazine-level layouts bring important things into the spotlight and make content structure clear.[/li][/ul]
[li]Privacy protection[/li][ul]
[li] New: MIUI 12 is the first Android-based mobile OS that went through the rigorous enhanced privacy protection testing.[/li][li] New: Reset your device ID and control how it’s used based on virtual ID technology.[/li][li] New: Grant permissions that will be used only while you’re using an app.[/li][li] New: You can also grant permissions just once, and decide again next time a permission is required.[/li][li] New: Restrict access to telephony to third party apps.[/li][li] New: Return blank messages to the apps that require personal information.[/li][li] New: Receive notifications whenever apps record audio, use camera, or access your location.[/li][li] New: Use secure sharing to control what additional data is sent along with shared items.[/li][li] New: Get comprehensive stats on how apps use permissions in app behavior history.[/li][li] New: Visit privacy.miui.com to learn how MIUI protects your privacy.[/li][li] Optimization: Apps aren’t allowed to launch other apps in the background now.[/li][/ul]
[li]AI Call Assistant[/li][ul]
[li] New: Mi AI can answer your calls now![/li][li] New: You can record a customized greeting that will be played to the other person during AI calls.[/li][li] New: Customized greetings are also supported for outgoing calls.[/li][/ul]
[li]Xiaomi Health[/li][ul]
[li] New: All-new Xiaomi Health gives you more options and makes your health stats more accurate.[/li][li] New: Put your device next to you before falling asleep to analyze your sleep cycle and record talking and snoring.[/li][li] New: You can sync data with supported wearable and smart home devices.[/li][li] New: Xiaomi Health can remind you to stand up and move when it detects that you’ve been sitting down for too long.[/li][li] New: The app also analyzes your stats and gives you simple health advice.[/li][/ul]
[li]Control center[/li][ul]
[li] New: Swipe down from the upper right corner of your screen to open Control center.[/li][li] New: Animated icons are a joy to look at![/li][/ul]
[li]Accessibility[/li][ul]
[li]New: Mi Ditto combines dictation and speech output, making mobile devices more convenient for people who have difficulties using conventionally designed smartphones.[/li][/ul]
[li]Trips[/li][ul]
[li] New: Traffic and suggested routes to airports and train stations.[/li][li] New: You can track your previous trips now.[/li][li] New: Checklists for trips.[/li][li] New: Alarms for train arrivals.[/li][/ul]
[li]Mi Carrier Services[/li][ul]
[li] New: View your SIM balance and mobile data usage stats.[/li][li] New: Save frequently used phone numbers to top up balance and buy mobile data later.[/li][li] New: Buy SIM cards and services.[/li][/ul]
[li]Messaging[/li][ul]
[li] New: Promotional messages are grouped according to their content now.[/li][/ul]
[li]Status bar, Notification shade[/li][ul]
[li] New: All-new design.[/li][/ul]
[li]Weather[/li][ul]
[li] New: New animations bring the weather from outside directly to your screen.[/li][/ul]
[li]Settings[/li][ul]
[li] New: Security introduces new comprehensive privacy protection mechanisms.[/li][li] New: Lite mode simplifies your device and brings essential features up front.[/li][/ul]
[li]File Manager[/li][ul]
[li] New: Use the floating shortcut to filter and sort items, as well as switch view.[/li][/ul]
[li]Calendar[/li][ul]
[li] New: New layout tailored for landscape orientation is available now.[/li][li] New: We added lots of fresh animations that will accompany your actions.[/li][li] New: Calendar cards will remind you about important events and anniversaries.[/li][/ul]
[li]Notes[/li][ul]
[li] New: You can create folders with notes now.[/li][li] New: New dynamic backgrounds look gorgeous![/li][li] New: Tasks are completed with a satisfying animation now.[/li][li] New: Checklists of subtasks make managing your agenda much simpler.[/li][/ul]
[li]Security[/li][ul]
[li] New: New animations feel natural and refreshing.[/li][li] New: Keep your home safe with smart home device alerts.[/li][li] New: Binging your favorite shows will be more convenient with our new video toolbox.[/li][/ul]
[li]Xiaomi Cloud[/li][ul]
[li] New: Shared family storage plan is available now.[/li][/ul]
[/LIST]
[COLOR=rgb(243, 121, 52)]DOWNLOAD LINKS
Download | Mirror
