[RECOVERY] [UNOFFICIAL] TWRP 3.1.0-0 for Xiaomi Redmi 4A [rolex] [20170318]
[CENTER]Team Win Recovery Project 3.x, or twrp3 for short, is a custom recovery built with ease of use and customization in mind. Its a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
[/CENTER]
CHANGELOG for 3.1.0-0:
[CENTER][ul]
[li]vold decrypt on a few select HTC devices, TWRP will now attempt to use the system partition’s vold and vdc binaries and libraries to decrypt the data partition (nkk71 and CaptainThrowback)[/li][li]adb backup to stream a backup directly to or from your PC, see documentation here (bigbiff)[/li][li]tweak MTP startup routines (mdmower)[/li][li]support new Android 7.x xattrs for backup and restore to fix loss of data after a restore (Dees_Troy)[/li][li]support POSIX file capabilities backup and restore to fix VoLTE on HTC devices and possibly other issues (Dees_Troy)[/li][li]better indicate to users that internal storage is not backed up (Dees_Troy)[/li][li]improve automatic determination of TW_THEME (mdmower)[/li][li]minimal getcap and setcap support (_that)[/li][li]try mounting both ext4 and f2fs during decrypt (jcadduono and Dees_Troy)[/li][li]shut off backlight with power key (mdmower)[/li][li]timeout during FDE decrypt (Dees_Troy and nkk71)[/li][li]support for FBE decrypt and backing up and restoring FBE policies (Dees_Troy)[/li][li]boot slot support (Dees_Troy)[/li][li]TWRP app install prompt during reboot (Dees_Troy)[/li][li]support for AB OTA zips (Dees_Troy)[/li][li]support new Android 7.x log command (Dees_Troy)[/li][li]update recovery sources to AOSP 7.1 (Dees_Troy)[/li][li]numerous bugfixes and improvements by too many people to mention[/li][/ul]
[/CENTER]
DOWNLOADS: twrp-3.1.0-0-20170318-UNOFFICIAL-rolex.img
[CENTER][/CENTER]
HOW TO FLASH:
[CENTER][ul]
[li]Fastboot Method : fastboot flash recovery twrp-3.1.0-0-20170318-UNOFFICIAL-rolex.img[/li][li]Boot to OLD TWRP > INSTALL > Select Image > Navigate to twrp-3.1.0-0-20170318-UNOFFICIAL-rolex.img > Select it & Swipe to Flash[/li][/ul]
[/CENTER]
[LEFT]CREDITS:
[li]TeamWin[/li][li]CyanogenMod[/li][li]Hyper[/li][/ul]
Contributors
darshan1205
Source Code: omnirom · GitHub
Version Information
Status:
Stable
Created 2017-03-20
Last Updated 2017-03-18[/LEFT]
Kernel Source: rolex_global_images_V8.2.1.0.MCCMIDL_20170306.0000.00_6.0_global_801a10c894
Flash lazyflasher to disable dm-verity & forced encryption on MIUI
WoW great work DSM… [emoji5]
