[ROM] || [VoLTE] ||- Viper -OS -||[21 May][Optimised]
[CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)]http://i64.tinypic.com/2zhgvf6.jpg
http://i.imgur.com/wSbwCpZ.png
[CODE]* Your warranty is voided.[/FONT][/SIZE][/CENTER]
[CENTER]* We are not responsible for bricked devices, dead SD cards,
  • Third World War, or you getting fired because the alarm app failed. Please
  • do some research if you have any concerns about features included in this ROM
  • before flashing it! YOU are choosing to make these modifications, and if
  • you point the finger at us for messing up your device, we will laugh at you.[/CODE][/FONT][/SIZE][/CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][/FONT][/SIZE]
    [CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)]Get more information about ViperOS on our telegram group - [COLOR=rgb(0, 135, 255)]JOIN
    [FONT=Trebuchet MS]Note: The builds are updated as soon as possible. There is no compilation cycle. Information about the device is displayed[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]properly. The current build is the latest build for your device. If the device is[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]scheduled to be released on a particular day, but the new build is not being displayed,[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]contact the maintainer of your device for more information, but wait at least 72 hours.[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Become a member of our G + community - [COLOR=rgb(0, 135, 255)]JOIN[/FONT][/FONT]
Quote:
REMINDER
[FONT=Trebuchet MS]If you are having problems and want to send a report (Logcat), make sure that you are reporting from the default kernel, not a modified one. Modified kernels can break or fix, even make things better. It depends. I cannot get a full hint of the problem when you’re not running the original kernel.[/FONT][/FONT]
[SIZE=5]Features:[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Status bar Customization[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Customizable icons[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Quick pulldown[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Smart pulldown[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Notification count[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Clock position[/FONT][/FONT][/SIZE][/CENTER]
[INDENT][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][/FONT][/SIZE]
[CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Seconds in clock[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Date design[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS][/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Quick Settings[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Brightness slider[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Brightness icon[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Tile tap customization[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Header customization[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]System[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Power menu customization[/FONT][/FONT][/SIZE][/CENTER][/INDENT]
[SIZE=5]-UPDATE INSTRUCTIONS-[/SIZE][/FONT][/SIZE]
  • [FONT=Trebuchet MS]Download the latest build of ViperOS ROM[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Take a nandroid backup[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Flash ROM usingrecovery[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Flash Gapps[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Wipe cache[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Wipe dalvik cache[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Reboot[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]- Enjoy![/FONT][/FONT]
    -Installation Files-
    [/FONT][/SIZE]
    [B][SIZE=5]Viper 11 June Stable[/SIZE][/B]
    [SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][COLOR=rgb(0, 135, 255)][SIZE=5]GApps[/SIZE][/FONT][/SIZE]
    [FONT=Trebuchet MS]Development[/FONT][/FONT]
    [FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]ViperOS Brasil Team[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Base[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]LineageOS[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Credits[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]crDroid Android[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]CypherOS[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]AICP[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]PureNexus[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]AOKP[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Dirty Unicorns[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Paranoid Android[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]and more…[/FONT][/FONT]
[FONT=Trebuchet MS][SIZE=5]Sources[/SIZE][/FONT][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][COLOR=rgb(0, 135, 255)]Device/Kernel and All
[COLOR=rgb(20, 20, 20)]ROM
[COLOR=rgb(0, 135, 255)]https://github.com/JBCDroid2[/FONT][/SIZE][/CENTER]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]Update :[/SIZE][/FONT][/SIZE]
[li][SIZE=4]FC’s and crash fixes[/SIZE][/li][li][SIZE=4]Fixed Slow Charging Issue[/SIZE][/li][li][SIZE=4]New Viper Wallpapers[/SIZE][/li][li][SIZE=4]Various optimisations and tweaks by new kernel [Thanks to @Shoaib05 for Mini Velocity :cool: for this awesome kernel][/SIZE][/li][/ul]
[SIZE=4]Download :[/SIZE]
Link bhejo
Sent from my YU5510 using Tapatalk
