[ROM] || [VOLTE][OMS] [7.1.2 r_5] || [Android Ice Cold Project] ||[29 April][STABLE]
[CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=7][FONT=Arial][B]http://i64.tinypic.com/2zhgvf6.jpg[/B][/FONT][/SIZE][/FONT][/SIZE]
[SIZE=7][FONT=Arial]✯ ✯ ✯ TEAM DESTROYER PRESENTS [/FONT]✯ ✯ ✯[/SIZE][/FONT][/SIZE][/CENTER]
http://i.imgur.com/GhQyhHk.png
[SIZE=5]AICP[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]Android Ice Cold Project[/SIZE][/FONT][/SIZE]
[FONT=Trebuchet MS][SIZE=4]AICP is known by everyone as Android Ice Cold Project that started on HTC Desire HD and since then evolved into a mature ROM with the BEST community you can find!!![/SIZE][/FONT][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS][SIZE=4]Until lollipop, ROM has always been AOKP based. Unfortunately, since AOKP either stopped development or will make a comeback later this year, we changed our base to CyanogenMod when it comes to hardware, drivers and some features.[/SIZE][/FONT][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)].
http://i.imgur.com/u0fJM9W.png[/FONT][/SIZE][/CENTER]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]Features :[/SIZE][/FONT][/SIZE]
[/FONT][/SIZE]
[FONT=Roboto Light]
[LIST]
[li][FONT=Trebuchet MS]System animations[/FONT][/li][/ul]
[li][FONT=Trebuchet MS]Toast icon and animation[/FONT][/li][/ul]
[li][FONT=Trebuchet MS]Power menu animation[/FONT][/li][/ul]
[li][FONT=Trebuchet MS]IME animation[/FONT][/li][/ul]
[li][FONT=Trebuchet MS]LCD density changer[/FONT][/li][/ul]
[li][FONT=Trebuchet MS]Some other customization in AICP Extras[/FONT][/li][/ul][/FONT]
[/LIST]
[/FONT][/SIZE]
[FONT=Roboto Light]
[LIST]
[li][CENTER][B]http://i.imgur.com/3U7XWsV.png[/B][/CENTER][/li][/ul][/FONT]
[/LIST]
[FONT=Roboto Light][SIZE=6]ROM :[/SIZE][/FONT]
[B]AICP N Optimised VoLTE 29 April[/B]
[/FONT][/SIZE]
[CENTER][SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][B]http://i.imgur.com/3ueQ7DH.png[/B][/FONT][/SIZE][/CENTER]
[/FONT][/SIZE]
[FONT=Roboto Light]
[LIST]
[FONT=Trebuchet MS]
[LIST]
[li]CM team[/li][/ul]
[li]maxwen[/li][/ul]
[li]SlimBean rom team[/li][/ul]
[li]CarbonRom team[/li][/ul]
[li]LiquidSmooth rom team[/li][/ul]
[li]Omni rom team[/li][/ul]
[li]DU team[/li][/ul]
[li]Community[/li][/ul]
@Abhiram Shibu [/FONT]
[/LIST][/FONT]
[/LIST]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]Source :[/FONT][/FONT]
[FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS]ROM :[COLOR=rgb(0, 135, 255)]https://github.com/aicp[/FONT][/FONT][/SIZE]
[SIZE=7]✯ ✯ ✯TEAM DESTROYER✯ ✯ ✯[/SIZE][/FONT][/SIZE][/CENTER]
[/FONT][/SIZE]
[li][FONT=Roboto Light][LIST][/li][li][FONT=Trebuchet MS][/li][LIST]
[li]@Neeraj55#5[/li][li]@Abhiram Shibu[/li][/ul][/FONT]
[/LIST][/FONT]
[/LIST]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]How to get VoLTE working:[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][ol]
[li][FONT=Trebuchet MS][SIZE=4]Download Modem from link below[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]Extract the zip.[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]Reboot the phone to fastboot mode.[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]Open the folder with VOLTE modem. Press alt + shift + right click and click on open command window here.[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]Enter the code :[/SIZE][/FONT][/li][FONT=Verdana][SIZE=5]fastboot -i 0x1ebf flash modem NON-HLOS.bin[/SIZE][/FONT]
[li][FONT=Trebuchet MS][SIZE=4]Press Enter[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]This will flash the modem files.[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]When it says OK disconnect the phone and reboot.[/SIZE][/FONT][/li][li][FONT=Trebuchet MS][SIZE=4]Enjoy[/SIZE][/FONT][/li][/ol][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][FONT=Trebuchet MS][SIZE=5]Downloads :-[/SIZE][/FONT] [SIZE=4][FONT=Tahoma][COLOR=rgb(0, 135, 255)]VOLTE MODEM[/FONT][/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=4][/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=7]Notice : [/SIZE][SIZE=4]Those who are facing data toggle issue[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=4]Download LTE discovery App from Play store[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=4]Click on discover tab and select Reset Data Connection and click start[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=4]Your internet will start working … :eek:[/SIZE][/FONT][/SIZE]
Thanks that was what I was searching about. By the way aicp, its very awesome … Smoothest ROM ever made!
Sent from my YU5510 using Tapatalk
Update :
[li]Latest AICP and Lineage Upstream Changes[/li][li]Data toggle fixed [Completely][/li][li]No network reset issue[/li][li]Ambient Display Added[/li][li]Night Light added[/li][li]Some other minor improvements[/li][li]Performance improvements[/li][/ul]
Note :Use latest OpenGapps :cool:
Download :
AICP N VoLTE Stable 3 March
WoW so aicp works now?
AICP rocks !!!
Update thread title
Sent from my AO5510 using Tapatalk
Update:
[li]Latest AICP and Lineage upstream changes[/li][li]Compiled with Qualcomm Snapdragon LLVM for better optimisation of battery and performance[/li][li]Update from r_21 → r_25[/li][li]Updated Substratum[/li][/ul]
Download :
[B]AICP N Optimised VoLTE 8 March[/B]
Note : Please do clean flash for best results :stuck_out_tongue:
You have attached the wrong link, please fix it.
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)]Update ::smiley:[/FONT][/SIZE]
[li]Rootless subs with FloatUI :eek:[/li][li]Destroyer-Kernel is back[/li][li]Some performance improvements[/li][/ul]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)]Download :
AICP N Rootless Subs VoLTE 9 March
[/FONT][/SIZE]
awesome work bro u r great;);):wink:
Hey !Hey !Hey ! What is up everybody , I am back with new and important update ::eek:
[li]Sync with Latest AICP changes[/li][li]Unbeaten Smoothness[As per testers reviews:rolleyes:][/li][li]On ur special demand for kernel I have rebased my kernel to Destroyer-Reborn [/li][/ul]
So i request you to use stock kernel for better results :smiley:
[li]RIP Slow Charging[/li][li]VoLTE improvements[/li][li]Performance improvements[/li][/ul]
Download :
AICP N Optimised VoLTE 23 March
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]Me iz Back with Update ::D:cool: @Arjun Chandran [/SIZE][/FONT][/SIZE]
[li][SIZE=5]Synced with latest AICP and Lineage Sources[/SIZE][/li][li][SIZE=5]Switched to 7.1.2 r_5[/SIZE][/li][li][SIZE=5]Improved UI :rolleyes:[/SIZE][/li][li][SIZE=5]Latest Android Security Patch[/SIZE][/li][li][SIZE=5]Support of much improved Destroyer Kernel [:cool:][/SIZE][/li][/ul]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]Download :[/SIZE][/FONT][/SIZE]
[SIZE=13px][FONT=Roboto Light][COLOR=rgb(20, 20, 20)][SIZE=5]AICP N Optimised VoLTE 29 April[/SIZE][/FONT][/SIZE]
WoW… installing it for sure… bye bye mokee
Hey that’s wonderful… Congrats Dev
Good to see you bro :slight_smile: :heart:
Is there pixel ui inbuild.In this rom.
Also why remove pure nexus rom thrrat from the forum ,i was downloaded, and can i flash that
Yes it has pixel hi
And pure nexus will be published when it’s totally stable
Waiting for it bro
