[CENTER]http://i64.tinypic.com/2zhgvf6.jpg
[B][FONT=Trebuchet MS][SIZE=6]✯ ✯ ✯ TEAM DESTROYER PRESENTS ✯ ✯ ✯[/SIZE][/FONT]
http://i66.tinypic.com/20huatw.png
[SIZE=5]GET RESURRECTED[/SIZE][/B]
[B]http://i67.tinypic.com/2dviyif.png[/B]
[SIZE=5]Based On Latest Google Android 7.1.2_r2 release[/SIZE]
[SIZE=6]|| RR Customizations ||[/SIZE]
[FONT=Trebuchet MS]-Enable/Disable Navbar
-Navbar Button Customization smartbar
-Navbar Pulse
-Navbar Fling
-Double Tap To sleep navbar
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Double Tap To sleep Statusbar
-Carrier Label
-Carrier Label Switch
-Carrier label Color
-Carrier Label Size
-Clock Customizations
-Time & date
-Day & date Toogle
-Center/Right/Left Clock Choice
-Date Format
-Clock Font Styles
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Network Traffic Arrows Switch
-Incoming/OutGoing Traffic
-Network traffic Color
-Statusbar RR Logo
-RR logo Color
-Position
-Custom Logos
-logo Color
-Position
-Style
-StatusBar Weather
-Weather Color
-Weather Position(left/right)
-Weather Font Style
-Weather Size
-StatusBar Ticker
-Ticker Text color
-Ticker Icon Color
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Power Menu Animations
-Misc Animations
-Gestures
-Gestures Anywhere Feature
-3 Finger Swipe Screenshot Gesture
-App Circle Bar
-Choose apps in AppSidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Trigger(left ,Right ,Bottom)
-Pie Targets
-Pie Colors
-More Pie Features
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Full Screen Recents
-Recents Styles
-OmniSwitch
-Clock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Bottom Shortcuts
-Lockscreen General Shorcuts
-100+ Icons for Shortcuts
-Double Tap to Sleep Lockscreen
-Lockscreen Media Art/Enable Disable
-Quick PIN/Patter Unlock
-LockScreen Wallpaper
-Lockscreen Weather Widget
-Lockscreen Icons Color
-Quick Settings Draggable Tiles
-Customizable Tiles
-Dyanamic Tiles Adjustment
-Number of columns/rows
-Tile Animations
-Notification Drawer
-LongPress Toogles to Enter Settings
-Disable Immersive Mode Messages
-Force Expand Notification
-Quick PullDown
-Smart Pulldown
-Notification Panel Transperency
-Volume Dialog Transperency
-Notification Panel Stroke
-Volume Dialog Stroke
-Buttons
-Backlight Timer
-Backlight Strength
-Advanced Reboot Menu
-Power Menu Customizations
-Power Off
-Reboot(Recovery, Bootloader, Hot Reboot)
-ScreenShot
-Power Menu End Calls Switch
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
-Home Button(For devices with HW keys Only)
-Home Button answer call
-Long Press Actions
-Double Tap Actions
-Menu Button(For devices with HW keys Only)
-Short Press Actions
-Long Press Actions
-Search Button(If Device Supports)
-Short Press Action
-Long Press Action
-Volume Buttons
-Wake Up Device
-Playback Control
-Ringtone Volume Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Volume Key Answer
-Miscellaneous
-Selinux Switch (Switch Between Permissive and Enforcing Selinux if Device has Selinux Enabled)
-cLock Shortcut
-Disable Battery Saver Warning Color
-OTA U
-Cammera Shutter Sound Enable/Disable
-SystemUI Tuner
-Enabled By default
-Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
-StatusBar Icons Cuzomizations
-Quick Settings Customizations
-Other Features
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-Heads Up Switch and customizations
-Live Display
-Configurable 0,90,180,270 Degree Rotation
-Lock Screen Autorotate Switch
-Native Tap to Wake From Marshmallow
-Double Tap Power Button To enable Camera gesture
-Prevent Accidental Wakeup
-Wake Phone on Charging Plug
-Battery Light Customizations
-Notification Light Customizations
-Font Size
-CM privacy guard
-Performance Tweaks(Kernel Aduitor Inbuilt)
-CM root inbuilt
-A Whole new RR Configurations
-OverAll Smoothness Improvements
-Optimizations to Improve Battery
-Includes All Android Nougat Features
-Includes ALL CM14.1 Features
-AND MUCH MUCH MORE
-INSTALLATION INSTRUCTIONS-
- Download the latest build
- Download Gapps
- Take a nandroid backup
- Recommended - Full wipe and factory reset
- Flash ROM using latest TWRP 3.x Recovery
- Flash Gapps
- Reboot.
- Enjoy!
-UPDATE INSTRUCTIONS-
- Download the latest build of Resurrection Remix ROM
- Flash ROM using recovery
- Reboot
- Enjoy!
-ROM UPDATES [FONT=Trebuchet MS]22[/FONT] APRIL-
- Sync with latest Lineage and RR sources
- Added more optimisation to kernel for better performance and battery backup
- Optimisation of boot animation for faster boot
- Some misc fixes and graphics performance improvement
- Data toggle fixed [Completely] - No network reset issue
- VoLTE is fully stable now
- Ambient Display Added
- Night Light added
- Some other minor improvements
- Performance improvements
[SIZE=4]-Added llvm
-Added Vulkan
-Added VoLTE icon
-Added Magisk
-Rootless Subs[/SIZE]
-Added New Kernel
-Added Kcal[/FONT][/CENTER]
[CENTER][/CENTER]
[LEFT][FONT=Trebuchet MS][SIZE=5]Source [/SIZE][SIZE=5]: [/SIZE]
[SIZE=5]ROM[/SIZE] :[/FONT]
[SIZE=4][FONT=Trebuchet MS]ResurrectionRemix · GitHub[/FONT][/SIZE]
Kernel :[/SIZE][/FONT]
[FONT=Trebuchet MS][FONT=Trebuchet MS]GitHub - Destroyer-OS/android_kernel_cyanogen_msm8916[/FONT][/FONT]
[/LEFT]
[CENTER]
[B]http://i63.tinypic.com/1zxtlr9.png[/B]
[B][FONT=Trebuchet MS][SIZE=6]Resurrection Remix 22 April
Open GApps[/SIZE][/FONT]
[/B]
[B]http://i67.tinypic.com/2nrnio8.png[/B][/CENTER]
[li][LIST][/li][li][FONT=Trebuchet MS]LineageOS Team[/FONT][/li][li][FONT=Trebuchet MS]DU Team[/FONT][/li][li][FONT=Trebuchet MS]Omni Team[/FONT][/li][li][FONT=Trebuchet MS]@Neeraj55#5 [/FONT][/li][li][FONT=Trebuchet MS]AND OF COURSE TO ALL THE SUPPORTERS AND USERS[/FONT][/li][/ul]
[/LIST]
[INDENT][INDENT][B][FONT=Trebuchet MS]
[/FONT][/B][/INDENT][/INDENT]
[CENTER][FONT=Trebuchet MS][SIZE=6]✯ ✯ ✯TEAM DESTROYER✯ ✯ ✯[/SIZE][/FONT]
[/CENTER]
