MIUI 9 China beta is out for tester but it’s a closed beta and many MIUI fans can’t get a first look on it. So here is the latest MIUI 9 Beta build as per 05-08-2017.
Note: This is a China Beta ROM and there so Google services and Chinese bloatwares are installed.
How to install MIUI9?
Simple flash the ROM via TWRP.
How to install with Google?
[li]Install TWRP via Fastboot.[/li][li]Flash the ROM.[/li][li]Now TWRP is gone! Flash TWRP again.[/li][li]Flash SuperSU via TWRP[/li][li]Boot into the ROM and Install Google Installer_2.0.apk[/li][li]Flash Gapps via TWRP[/li][/ol]
[COLOR=rgb(89, 179, 0)]DOWNLOAD
MIUI 9 China Beta
Build: 27-07-2017
MIUI Version: 9.7.7.28
Android Version: 7.0
Filename: miui_HMNote4X_7.7.28_e5b1c02b01_7.0.zip
File size: 1.28 GB
ROM Type: Flashable Zip
