RYZEN 7 1700 or 7700K - I'm confused!
I’m planning for a new build and now with RYZEN I’m confused. I wanted to go with latest gen Intel CPU but R7 1700 seems to offer more when it comes to price to performance. I wanna render 4K videos using Adobe Premier Pro and play graphic intensive games. If I’m getting RYZEN then ill try to get ROG Crosshair VI and if I’m getting the 7700K or 7600K then I’ll get ROG STRIX Z270F.
Suggest me which cpu I should go with!
Amd is not best for gaming… Because clock speed is low. It will be great for video editing… As you have more cores…:wink:
What i heard was totally different! RYZEN in all videos claim to out perform in Gaming and for productivity. Most games now need more cores same is with some productivity softwares.
I’m RYZEN release video they claim that the 1700 gives a 50% more performance in gaming. While Intel had a bit trouble in fps.
I would go with Intel if have a budget to get one.
A Response to the Hate and Garbage Surrounding RYZEN - YouTube
still bios needs stability updates (very soon to judge)
So the existing zen motherboards will need BIOS upgrade?
everyday bios updates are coming to ryzen boards to maximize stability
And again i chose to go with Intel!
Intel is more stable! Has more life and more value!
how can u judge its life with a day old processor?
It can be judged by the brand!
Exactly @redblade I judged by the brand name.
