I just installed Crysis 2 (cracked copy) and when i launched it i got this error
“the application has failed to start because its side-by-side configuration is incorrect…” How to fix this?
I had this error before it’s most likely because you haven’t installed the Visual C++ redistributable packages that came with the game.
Try checking the game files and see vcredis files and Install it.
If thats didn’t work then try reinstalling the game.
Hey thanks, it worked i found the vredist.exe file along with game installer and installed it.
Thanks for the help
