Im not able to boot any windows uefi usb ,it is giving this error
What is the issue?
Things i tried:
reset my bios
enabled legacy
did clean from diskpart
Were u able to boot from USB earlier. I mean, in past…
yes, but now it seems only non uefi usb are bootable ,i tried windows7 mbr , did convert gpt to mbr and installed.
Unfortunately it seems my laptop doesnt support w7, i went to the site their drivers are for w10 ,i couldnt connect to internet , wifi , ethernet, tethering , even usb was not detected .I want to install uefi w10.
i have ssd and hdd , shall i disconnect the hdd and try?
Have you done any BIOS upgrade
nop
So you have 2 sata ports? or replaced DVD drive?
replaced dvd
This seems awkward…
Change settings to UEFI only in bios
If you can, also update ur BIOS
still not working
tell Laptop ,model
hp 15ab210tx
I cant stop laughing ,
After bios update too it didnt get patched, the actual problem was in windows iso or rufus i cant tell
, i downloaded new windows iso and made its usb with rufus which was given with it and it worked !
