HEllo
I have laptop HP Pavilion 15-Ab522tx
OS: Windows 10 (64-Bit)
Wireless card installed: 802.11b/g/n (1x1) and Bluetooth® 4.0 combo
The wifi is always quite low on it because it has a 2.4GHz adapter installed. I want to upgrade the wifi adapter card inside to a 5GHz wifi card with the bluetooth combo.
What adapter is compatible to safely install to get 5GHz wifi + Bluetooth combo for my model? Help!
Any suggestions on what will work or where to go to find out would be tremendously appreciated!
