WiFi option is missing on my laptop randomly
Today when i booted my laptop running windows 11 I was not able to find the wifi option and could not connect to wifi. How to fix this? is this a hardware issue?
This is the new bug arised from the recent update from windows, try to reset the network drivers/adaptors and restart the laptop which worked for me but still sometimes wifi option wont show up but after restarting it will reconnect to wifi. This issue will be rectified with upcoming updates and patches.
Yeah, I troubleshoot network hardware and it was fixed automatically. I’ve seen my windows laptops getting crazy with the wifi adapter it really annoying.
Check for driver update internally and also don’t forget to check hardware it may be hardware issue. If did’nt work buy a external wifi adapter
