• Zero Spam Tolerance Policy is now in effect. Any accounts posting spam will be permanently banned without warning. Learn more
Solved backup with Macrium Reflect
Aina
Silver Member Nova
Jun 5, 2021
3
2
800
35
I did a search for backup tools and I found Macrium Reflect to back up to external Harddisk.
I need to know if Macrium has the "resume" option? As my current Laptop has a lot of files/ folders which I think it will take longer to be copied, Also can it copy the files while it in use?
I also came across another tool called Gs Richcopy 360, Did anyone try that? Is it really faster and secure? and can it copy the files while it in use?
Please advise.
I had the good luck to try Gs Richcopy 360, it does all that I need, it has rich features and works as they promised, so, please close this thread, my problem has been solved
Topics You Missed
