Hard disk clicking sound
Jacksparow
Jun 1, 2018
29
1,800
My 500gb seagate hdd stopped working suddenly following repeated clicking noise from almost 2 months.
When its connected there's a clicking sound.
And system totally gets stuck when its connected.
Can i repair it??
Or can I just even recover my data?
Data recovery is important to me😰
littlewit
Active Member
Dec 31, 2016
38
2,765
That clicking sound is the actuator arm assembly returning back to its parked position forcefully, because it doesn’t know where to go, and can’t initialize.
If this happens too many times, it will cause damage to the read/write heads rendering the drive useless, and data inaccessible without a head swap. The actuator arm assembly has the read/write heads attached to the end of it, and is the mechanism responsible for reading data from, and writing data to the platters.
Jacksparow
Jun 1, 2018
29
1,800
Thanks littlewit littlewit,
So can i recover my data myself or should i hand it to professionals?
219
9,350
Can i repair it??
Its called click of death... It means most probably head is dead
Data Recovery is possible by replacing head. Contact professional help.
jmjxperia
Active Member
Feb 17, 2018
112
4
2,850
Why it happens?
Sent from my AO5510 using Tapatalk
Topics You Missed
