If it is badly damaged and deleted you can also try Test Disk which is free and I have used in the past to recover my 2 tb hd of files that was mangled.
TestDisk Download - CGSecurity
TestDisk is
OpenSource software and is licensed under the terms of the
GNU General Public License (GPL v2+).
TestDisk is
powerful free data recovery software! It was primarily designed to help
recover lost partitions and/or
make non-booting disks bootable again when these symptoms are caused by
faulty software: certain types of
viruses or
human error (such as
accidentally deleting a Partition Table). Partition table recovery using TestDisk is really easy.
TestDisk can
- Fix partition table, recover deleted partition
- Recover FAT32 boot sector from its backup
- Rebuild FAT12/FAT16/FAT32 boot sector
- Fix FAT tables
- Rebuild NTFS boot sector
- Recover NTFS boot sector from its backup
- Fix MFT using MFT mirror
- Locate ext2/ext3/ext4 Backup SuperBlock
- Undelete files from FAT, exFAT, NTFS and ext2 filesystem
- Copy files from deleted FAT, exFAT, NTFS and ext2/ext3/ext4 partitions.
TestDisk has features for both novices and experts. For those who know little or nothing about data recovery techniques, TestDisk can be used to collect detailed information about a non-booting drive which can then be sent to a tech for further analysis. Those more familiar with such procedures should find TestDisk a handy tool in performing onsite recovery.
Operating systems
TestDisk can
run under
- DOS (either real or in a Windows 9x DOS-box),
- Windows 10/8.1/8/7/Vista/XP, Windows Server 2016/2012/2008/2003
- Linux,
- FreeBSD, NetBSD, OpenBSD,
- SunOS and
- MacOS X
