Best budget case?
Hello what do you think is the best budget case? In terms of durability and design for atx. I’m planning to change my generic case
I’m using the Thermaltake Versa N26 case, its really awesome for the money.
It’s a windowed case, the uts rigid. The material is hard and you will get a USB 3.0 port too. Plus there is a HDD rack and two other mouthing areas.
I see, how much did you pay for yours? Also any ideas for mounting laptop hdds on a case?
It was only $61. And an SSD mounting bracket can help you mount laptop HDD to a PC case.
I see, thank you! What happens if you put the hdd on the bottom of the case temporarily?
Nothing!
Thermaltake Versa N21 looks dope. But Corsair has some good budget cases as well.
If you can get an NZXT case in some deals or offers then that will be best. They know how to make a good case and has most things that a case needs.
Corsair and Cooler Master are also a great option if you have more to spend.
I’m using Armaggeddon Nanotron T2X. It looks dope for such a low price.
lian li cool 2
i agree with 24keoni lian are decent
I believe you can get a Coolermaster Masterbox for around 60 on Amazon right now.
I find the brand phanteks really good and adorable the even come with RGB and dust filters it’s aroundn75€
I think the Phanteks Eclipse P300a Mesh is best as it has a lot of space, a good design and good airflow.
I think my case is 450x
Corsair Carbide Series
This is one of the newer affordable cases from the company, a mid-tower constructed with clear lines and toned with an RGB cooling fan on top, lighting the CORSAIR logo and point-to-point tempered glass view panel. The Corsair Carbide Series 175R is one of the company’s ecosystems of gaming gears. You can take test keyboards, mice, headsets, power affords, gaming chairs, cooling processes (fan, CPU cooling custom reducing), and storage from them.
I own this case and I can confirm 100% that it’s totally worth the money and probably even more. I have everything at that cheap price. Tho I got fooled by the seller on amazon saying it’s tempered and I go the one with acrylic.
But it looks clean, minimalist, and professional with the excellent build quality.
For budget case I prefer cooler master for its unique design and better air flow options.
