:neutral: The CORSAIR 570X has both sides of tempered glass! what’s the point? When I do cable management all most part of the cables go behind the motherboard tray and they are covered by the other side.This case has both sides windows which will definitely show the mess even if you hide your cables under a power supply shroud. So why does anyone wanna use CORSAIR 570X or any such cases with both sides open?: unamused:
Same reason there is 4 way titan build for show,especially with the 460 & 570x
All the beauty of the build can only be seen on one side. Right?
If u r good at cabke management then put some lights on that side as well and show off you cables as well
Usually, I sacrifice the looks of one side to make the other look more appealing. And hide that untidy side with the case side panel. ![]()
Thats cuz(no offence) you arent great at cable manahement but for those who do its worth it,Also what happened to u building a budget pc
Well it’s in progress, I got the case and PSU. Now im making money for the mobo that will be a STRIX 270F.
Hows a z270 a budget mobo,u could get a Z170 and maybe borrow a skylake cou and then updating the bios
I’m currently using a Sandy bridge PC and so I’m wanna upgrade to the latest tech available. So that i won’t be outdated so soon ![]()
Z170 isn’t outdated
Yeah but will be sooner than z270.
Not true,its still the same socket type only the chipset is different
Yes but z270 chipset has full support for 7th CPUs and it also is Intel octane memory ready.
And also I’m an ROG fan.
So there are Z170 ROG mobos as well,but it’s your pc so its up to you.
Yup these are my personal choices. Anyway im building so im going all new. Btw this won’t stay in budget anymore.
s340 elite by nzxt seems good tho
Yeah, NZXT has some awesome cases. They know how to design!
A good cable management looks really good too ( specially using custom cable). Anyway this cases with both sides on tempered glass are designed thinking about custom liquid coolers. I saw some designs using that rear side and looks awesome!!
Custom cables will look awesome.
