Built this in October… . I started streaming in 2018 on a system that really wasn’t good enough (FX-6300, Radeon R7 250, 1x8GB DDR3 800MHz) and I eventually built this much better PC - didn’t bother with RGB.
[ATTACH type=“full” alt=“94780501_678157039664449_1749784277957869622_n.jpg”]224[/ATTACH]
Just pasted this from my twitch panel so it includes peripherals
OS: Windows 10 pro.
Mobo: ASRock B450M Pro4 Micro ATX
CPU: Ryzen 5 1600
GPU: EVGA 1660 Ti SC Gaming Ultra 6GB
RAM: Corsair Vengeance LPX 2x8GB DDR4 3200MHz
Case: Cougar MX 330
Storage: Samsung 860 Evo 500 GB SSD, Seagate Barracuda Compute 2 TB HDD
Controller: PowerA Xbox One Enhanced Wired Winter Camo
Monitors: Primary-MSI Optix G27C4 27" 165Hz E243PV-FHD, Secondary - Sceptre E243PV-FHD
Mouse: Glorious Model O Matte Black
Keyboard: HyperX Alloy Origins
Headset: HyperX Cloud Alpha S
Webcam: Logitech C270 - I’m using a visual effect, my image has been sanitized for your protection.
PSU: Insignia 450W (Temporary, substituting for defective SeaSonic S12III 500W)
USP: CyberPower 550SLG
(Prophet)
May 10, 2020, 5:56am
2
RayThePurple:
OS: Windows 10 pro.
CPU: Ryzen 5 1600
Case: Cougar MX 330
Mmmmmm… That is a good pc for 1080p gaming and productivity. But why did you choose an mATX motherboard in an ATX case? It looks empty. And there seems like cable management to be done. It will be better if you can pull the cables that ate sticking out to the back of your motherboard tray. Also it looks loke a desert man you need to do some dusting.
That is such a great PC bro! I hope you enjoy it. and I hope 1 day I could build a good PC just like yours.
I didn’t choose it…I know a guy on discord, he chose the parts because he knows much more about this stuff than me. I don’t care about the looks… it’s not ‘on display’ I barely ever look at it.
LOL yea I don’t care about looks and led lights either. Nice rig you got!
the specs looks good but does need some cleaning work
You can stream even on a budget PC, OBS studio is doing wonders.
My specs are 9 years old and I can do streaming sessions for 5+ hours.
If you want recommendations, check this out - Best Streaming Software for Low-End PC - Top 7 Picks in 2022 . Lightstream Mixer works even under older versions of Windows.
Happy streaming.
