Source Code : https://aur.archlinux.org/packages/chromium-vaapi/
Binary File : https://abhiramshibu.tuxforums.com/archlinux/chromium-vaapi-85.0.4183.102-1-x86_64.pkg.tar.zst
CheckSUM MD5 : 35eb3698792cdd914c8f5431d375bb30
[CENTER]
[COLOR=rgb(184, 49, 47)][SIZE=6]Instructions.[/SIZE][/CENTER]
Download the binary file.
Use gui package manager or command [FONT=courier new]“sudo pacman -U ” [/FONT]to install the package.
Configure chromium to force enable hardware acceleration.
[I]File ~/.config/chromium-flags.conf
--ignore-gpu-blacklist
--enable-gpu-rasterization
--enable-zero-copy
--use-gl=desktop
--enable-accelerated-video-decode
[/I]
[FONT=arial]4) Start or restart chromium.[/FONT]
[CENTER]
[SIZE=6][COLOR=rgb(184, 49, 47)][FONT=arial]Disclaimer.[/FONT][/SIZE][/CENTER]
[I][SIZE=4][FONT=arial]1) I am not responsible if something happens to your hardware, personally I am using this same binary file and there was no issues with it.
I will try my best to update the binary file, chromium does take a lot of time to build so I thought it would be nice if people just get a compiled version.
I do not own the source code or has any copyright over it. All the credits goes to the original maintainer.
Not tested in manjaro but I will add my remarks here after testing.[/FONT][/SIZE][/I]
[CENTER][SIZE=6][COLOR=rgb(184, 49, 47)][FONT=arial]Test Results[/FONT][/SIZE][/CENTER]
[li][COLOR=rgb(65, 168, 95)]Arch Linux [PASSED] [14092020][/li][li][COLOR=rgb(250, 197, 28)]Manjaro Linux [PENDING] [/li][/ul]
