Fans/Motherboard not turning on
hey, so im building a pc and i’ve hooked up everything… only things im waiting for is thre graphics card and cpu… but the thing is when i plug everythig together and try to start it up the fans should spin.. but they dont and i was just wondering what i can do to fix this problem … (Case: Nzxt H510)
(Motherboard: Rog Strix B450-f)
You will need to install the CPU for the case fans and motherboard to turn on. :slight_smile:
