The new ibuypower pc that I bought recently and when I connected everything, turned it on I’m not getting any display output.
I checked both monitors are working by connecting to my laptop. So far I have tried reseating the graphics card, made sure both ram sticks in proper slots, and seated them properly.
Please help.
EDIT, here are the specs:
Case: BUYPOWER Lian Li LANCOOL ONE Tempered Glass RGB Gaming Case
Processor: Intel® Core™ 19-10900X Processor (10X 3.70 GHz /19.25MB L3 Cache)
Motherboard: ASUS Prime X299-DELUXE 11 - WiFi, ARGB Header (1), USB 3.2 Ports (2 Type-C, 4 Type-A), M.2 Slot (2)
Memory: 32 GB [16 GB x2] DDR4-3200 Memory Module - Certified Major Brand Gaming Memory
Video Card: NVIDIA GeForce RTX 3070 Ti - 8GB GDDR5X (VR-Ready)
Case Lighting: None
Power Supply: 750 Watt - 80 PLUS Gold Certified
Processor Cooling: IBUYPOWER DEEPCOOL GAMERSTORM RGB 360mm CASTLE 360EX Liquid Cooler
Primary Storage: 1TB WD Black 3D Series SN750 M.2 PCIe NVMe SSD – Read: 3470MB/s; Write: 3000MB/S
Secondary Storage: 2TB Hard Drive – 256MB Cache, 7200RPM, 6.0Gb/s - Single Drive
Have you contacted ibuypower? Assuming that you have already done that, please give more info.
[li]Specs?[/li][li]Are the HDMI cable connected to the GPU and not the motherboard?[/li][li]Does the computer power on?[/li][li]Do fans work? Hear any noise?[/li][li]Do you hear any post error codes when it boots?[/li][li]Is there an onboard video?[/li][li]Are the cables are working?[/li][/ol]
I have already emailed them but havnt received any response yet. I tried both the motherboard ports and graphics card ports with no display for either.
Both the fans and light work, The cables are working.
