I7 9700K Overclocking
Hey guys I recently got an I7 9700K and a RTX 2080 with a Corsair H115i Platinum cooler.
Never done OCing before and I have had a look online and when I try to find a guide they all seem to use i9 9900ks as a guide.
I have a pretty good cooler so I imagine OCing should be alright, can anyone help me do it?
Thanks
What motherboard do you have? Overclocking is actually pretty easy these days. Like In my Asus motherboard I can just change the core ratio in the bios or simply just use Asus AI Suit and it will automatically find the best overclock for my CPU.
asus prime Z390-A
Okay then you can easily apply a suitable overclock using ASUS AI Suite software, download it from your motherboard support website: PRIME Z390-A Driver & Tools | Motherboards | ASUS India
Thanks @madkataw !!! Now i’m busy i’ll try later
