I thought to cheap out the case after all Thermaltake is not bad. But will ROG Maximus IX perfectly fit in the Thermaltake Versa n26 case with GTX 1050 ?
It should fit properly but you might need to remove the DVD drive cage as it is not used now and also frees more space.:idea:
It will Mr.red blade. Both are at standard.
Ok guys
