FIX Redmi Note 9 Pro "The system has been destroyed"
877
If you are like me and was doing some miscellaneous things using fast boot or recovery or whatever and screwed up your phone then here is the solution to fix "The system has been destroyed " error on your Redmi Note 9 Pro. I didn't try this on the Note 9 or Note 9 pro max so I don't know about them.
  1. Extract the "vbmeta.img" to ADB fastboot folder (where the fast boot is installed, if you don't have fastboot installed, download and install it from the attachment below ).
  2. Open command-line tool and paste: fastboot flash vbmeta vbmeta.img
  3. Boot to recovery by pressing and holding Volume Up and power buttons.
Reply and show some :heart: if this helped.
  • vbmeta.zip
  • Minimal ADB Fastboot v1.4.3.zip
9,350
Hope that helps
Thanks.. My phone is now alive from dead thanks to you!
peterunbekannt
Nov 28, 2021
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash vbmeta vbmeta.img
target reported max download size of 134217728 bytes
sending 'vbmeta' (4 KB)...
OKAY [ -0.000s]
writing 'vbmeta'...
FAILED (remote: not allowed in locked state)
finished. total time: 0.016s
Otto38
Dec 17, 2021
4
500
Thanks for sharing it! I really helps :D
8lackie
Jul 3, 2022
I'm getting "disc image file is corrupted" when i try to put vbmeta.img in my fastboot cmd line.
Edit: I made sure I had permissions for the files, and tried again, then I got "cannot load 'vbmeta.img no such file or directory. Maybe I'm doing something wrong?
