Best monitor under 10k - Dell S2216H
[CENTER][SIZE=5]Clean, sleek design[/SIZE]
Added elegance: Glossy, ultrathin bezels, a classic black piano finish, and an aluminum painted riser create and elegant monitor perfect for any home environment.
Easy, intuitive access:
Intuitive capacitive touch buttons on the bottom bezel offer a sleek and seamless finish.
Sturdy stand:
Easily tilt your monitor at your convenience with the robust stand.
http://i.dell.com/das/xa.ashx/global-site-design%20WEB/75d4ada1-f1e5-2994-c831-5e6bbd1dbd59/1/OriginalJPG?id=Dell/Product_Images/Peripherals/Output_Devices/Dell/Monitors/S_Series/S2216H/pdp/dell-monitor-s2216h-pdp-module-03.jpg
[SIZE=5]Rich sound, vivid visuals[/SIZE]
Maximum viewing area:
Get the most out of your 21.5" (54.6cm) viewing area with bezels almost half as thin as their predecessor.
Impressive screen performance:
Experience rich, accurate and consistent colors across a 178° ultrawide viewing angle in Full HD 1920 x 1080 clarity.
Superb clarity:
Minimize reflections with a sleek, remarkably clear screen.
Engaging audio:
Dual 3W integrated speakers create the perfect audio complement to your viewing experience.
http://i.dell.com/das/xa.ashx/global-site-design%20WEB/bdb0242a-96a3-aa39-3c85-2716835e8f6a/1/OriginalJPG?id=Dell/Product_Images/Peripherals/Output_Devices/Dell/Monitors/S_Series/S2216H/pdp/dell-monitor-s2216h-pdp-module-04.jpg
[SIZE=5]Designed for peace of mind.[/SIZE]
Plug and view:
Get easy compatibility with both legacy and future-ready PCs via VGA and HDMI connectivity.
Peace of mind included:
Relax knowing that your Dell monitor comes with Advanced Exchange service1 which is included as part of our standard 3-Year Limited Hardware Warranty2. You can also upgrade to ProSupport for 24x7 tech support for help with set up, troubleshooting and more, plus Advanced Exchange with next business day monitor replacement3.
Reduced environmental footprint:
The Dell 22 Monitor features PowerNap technology that reduces screen brightness or puts the monitor in sleep mode when it’s not in use. This monitor also meets the latest regulatory and environmental standards:
[li]ENERGY STAR® Qualified[/li]
[li]EPEAT® Silver Rated[/li]
[li]CECP Certified[/li]
[li]TCO Certified Displays[/li][/ul]
Environment-friendly materials: Your new Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR) - and PVC-free laminates.
[SIZE=5]BEST BUY :[/SIZE] Amazon.in: Buy Dell S2216H 21.5-Inch Full HD LED Monitor Online at Low Prices in India | Dell Reviews & Ratings
**though u can get a better buy at local shop
[/CENTER]
I love this design but I’m looking for a 1080p 27inch IPS monitor. Any suggestions?
budget?
20k
http://www8.hp.com/emea_africa/en/products/monitors/product-detail.html?oid=10402875
its avail here for 18k seems good tho check this in your local or some online ones
Ohk, thanks
BenQ GW2255HM. pretty good
here is the update but if you going for gaming, I would suggest you to go with a high refresh rate monitor.
