Graphics Requirement Site
How good is this site to check graphics requirements?
Site: Requirements Test
https://www.systemrequirementslab.com/
This is one that I used for years! You just gotta let it scan your computer to see what gear you’re running and it will tell you how well you can run a game.
It’s the same one I shared.How accurate is this?
Sent from my RMX1851 using Tapatalk
It’s worked very well for me in the past! Use it as a rough guideline to see if you can run things. If its saying your gear can only just about run a game expect a bad experience. Running it at 720p might help
Thanks
Systemrequirementslab and canyourunit are typically my go to websites to get a baseline.
are there data accurate?
Try using game-debate website …
