All of the devices like windows/ android when my headphones/ Bluetooth keyboard go to sleep after being inactive for some time, they don’t reconnect automatically. Even If I go manually in the bluetooth settings, It doesn’t work sometimes I need to forget the device, and re-scan and reconnect.
While on windows/ android/ mac it just reconnects as soon as I type some key on my keyboard.
Is this issue solved?
@pr0ph3t edited
@Abhiram Shibu
In my laptop it works fine. So u might wanna install bluez and blueman.
@Abhiram Shibu bluez and blueman both are already installed
I’m marking this solved, It seems after I repaired them, they’re auto connecting pretty fast.
