I am facing this issue from past 2 days even though it says bluetooth is connected but i can’t able to listen anything in earbuds , it is taking system output and also there is headset icon appearing , any help apperciated
Does it connect and work properly with your phone? or have you tried it on any other devices?
yess , no worries i figured out the. solution , basiaclly mac got an update i didn’t do , i have done it now , it works fine
Thanks for the update, sagarsagar. Good to know the issue was just due to a pending macOS update. I was having a similar problem, and this gives me a good starting point to check. Cheers!
What helped me was turning Bluetooth off and on, then unpairing and pairing the earbuds again. Also, make sure in your sound settings the earbuds are chosen as the output. Sometimes restarting the Mac Air after all that does the trick.
